H bridge using N mosfets torque problem?
Discussion in 'The Projects Forum' started by thekaiser11234, Apr 29, 2012.
  1. thekaiser11234
    Apr 29, 2012
    25
    hello im using My1016 motor wich is 14 ampere /24 volt 250 watt rated motor ,,
    im using an H bridge all NMOSFETS transistors and IR2110 driver
    the problem is when i measure the voltage delivered to the motor its 9v when i connect 12 v as volt for driving the mosfets and for the motor
    and the mosfets Drain/ source corresponding to MOTOR terminals have like 10.8 volt
    the problem that i feel tourque is reduced as i can stop the motor using my bare hands
    which i cant do if motor is connected to battery directly
    if im using the Driver and stopping the motor using my hands to stop it it gives 1,15 ampere MAX
    which is too low for the motor
    the mosfets get way too hot im using IRF3205
    im connecting the IR2110 to the gate of transistors using 330 ohm resistor
    im using " Arduino " with pwm frequency 500 hz,and duty cycle 98% (for the bootstrap capacitor )
    i hope its sufficient information for u and if u need more i can provide
    my 1st hope to keep going with the forum and to help others as u doo :)
    Thanx
  2. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
    Can you post a schematic of the setup?
    That way we can see if there are corrections needed.
    Bertus
  3. praondevou
    Jul 9, 2011
    2,936
    489
    Verify if your bootstrap voltages are at the correct level. With a 12V battery they are probably at most around 11V.
    The bootstrap cap is charged when the lower FET is conducting, i.e. it needs to be conducting for a time sufficiently long.
    And, yes, a schematic helps.
  4. thekaiser11234
    Apr 29, 2012
    25
    thank you guys for replying
    @praondevou wat do u mean with bootstrap voltages like which terminals u mean excatly ??
    @bertus
    yes i will provide u guys with the schematics by mid night as they r not available to me now
    thanks for showing interest
  5. praondevou
    Jul 9, 2011
    2,936
    489
    Pin 6 to Pin 5 (Vb to Vs).
  6. thekaiser11234
    Apr 29, 2012
    25
    C1, C5, C6 : 100uF
    C3, C4, C7, C8: 10uF
    C2 : 100nF Polyester Capacitor
    D1 : 1N4001 Diode
    D2, D3, D4, D5, D6 : Schottky Diode
    Q1, Q2, Q3, Q4 : IRF3205 Power MOSFET
    R1, R2, R3, R4 : 330 ohm resistor
    U1
    U2, U3 : IR2110 High and Low Side Driver
    PWM are fed into pins 10 and 12 on IR2110
    dc source is the motor battery ,12 v is for mosfets to operate and to be regulated to 5 v and used for ir2110
    im srry i m late and the schematic looks **** but i had do it again cuz the old schematic is not available to me :(
    any thing u wana ask please tell me
    hope u can help me
    thnx
  7. wayneh
    Sep 9, 2010
    12,374
    3,226
    Maybe not relevant, but you need a good ground line for the motor current. You haven't really indicated any ground connection between motor power and control power. I'm sure you have one, but it needs to be more-than-enough. Use a nice fat wire until you sort this out.
    thekaiser11234 likes this.
  8. praondevou
    Jul 9, 2011
    2,936
    489
    The sources of the upper FETs are not connected to the driver (pin 5 as far as I remember).
    Could you maybe bring this schematic into a more readable format? ;) Something similar to figure 28A in this Application note: http://www.irf.com/technical-info/appnotes/an-978.pdf
  9. thekaiser11234
    Apr 29, 2012
    25
    Vb to Vs shall be 12v ? for both of 2 ICS ??
  10. praondevou
    Jul 9, 2011
    2,936
    489
    Yes, at least. Their capacitors are charged through the low-side FET.
