H bridge Simulation
MikeML
5,444
The base current of the NPN s is only (1-0.65)/1k = 350uA
As Zapper points out, the base drive for the PNPs is totally wrong
Chacabucogod
Joined Nov 16, 2013
26
Well. If I tried to make this into a high voltage h bridge (120 V) I certainly wouldn't use a 120 volts signal to drive the BJTS. Is there another way to do this?
Thank you.
MikeML
5,444
What are you trying to drive? Voltage? Current? What provides the drive signals? What is the switching rate? PWM?
