h-bridge inverter using ir2110 causing problems
Discussion in 'Electronics Resources' started by bilal sheikh, Apr 20, 2015.
  1. bilal sheikh
    Jan 21, 2015
    22
    hello, i am trying to build an inverter using ir2110 and 10n60g n-channel mosfets. schematic is attached. Screenshot (58).png
    on hardware, i am using in4007 diode instead of uf4007. the pwm signal which i am giving on hin and lin is 6.4khz, 5v signal that has duty cycle of upto 80%.
    now the roblem is that i am not getting ho and lo accordingly. ho is constantly at 12v irrespesictive of signal at hin. can someone help ? is the schematic which i am following has errors, kindly help.
  2. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,524
    bilal sheikh likes this.
