H-bridge inverter board (single phase)
bilal sheikh
Joined Jan 21, 2015
22
hello everyone,
i want to know that is there an h-bridge inverter module exists?
i have my final year project which is variable frequency drive (speed control of single phase ac induction motor).
i have generated spwm signals using pic mcu through which i can achieve variable frequency. however, i am stuck with the inverter and now want to use an inverter module due to lack of time.
kindly tell if something like that exists.
thank u.
MaxHeadRoom
Joined Jul 18, 2013
28,703
If you intend to go through to a working model I would ensure that you use a single capacitor start/run style motor, otherwise you may see drop out of run at either/or low rpm and load.
Max.
