Hi All
I see there has been quite a bit discussed on H-Bridge stuff. I am trying to drive a 12V DC motor for a gate valve. It is anticipated that a normal automatic gate motor will be used so I guess the currents will not be more than about 20-30A.
The project manager insist on only using N channel FET's and one of the IR H-Bridge devices such as the IR2110. I have readup on the IR devices but cannot fathm out if these take care of the Vgs issue on the high side that normally would require a charge pump o sustain the say 10V Vgs when the high side FET opens up.
Do these devices do this as the tech notes are not very clear?
Are there any recommendations, examples that anyone has that I may use as a starting pont?
I am going to drive the whole system from a STM32F103CBT6 device. I also need to do some current sensing to detect shoot through faults, locked rotor etc, so will use op amps onto the AD's of the micro.
Any help greatly appreciated.
Regards
Dead Short
Regards
Dead Short
