I am pretty new to electronics. I want to design an H-bridge so I may switch a Linear Actuator On/Off and reverse the polarity using a microcontroller. The Motor/Linear Actuator is rated at 12V, 5A on load. The Microcontroller can generate 5V and a Maximum of 40mA to switch the circuit. How many inputs would I require from the Microcontroller? What kind of transistors and with what power ratings should I use?
-Falven
-Falven
