Hi, i need help in this project.
I have a step up from 9 to 180v. And i need to drive a load with controlled current from 0-150 mA, the load varies from 0-1kohm.
Idea:
1-Step-up gives the Power
2-I need a current source with voltage controller. Problem how? Any ideas?
3-Drive the amps throw a H bridge, so i can +-current.
4-What to use, mosfets or bjts?
What i was trying to do was, i have the power and connect the dc/dc to the h-bridge, and putting a high voltage bjt npn connected like this base 5v throw a dac, in the emissor resistance with 25ohm, so i can have the current i need, throw the emissor and collector. Problem, the top transistors PnP, and i wanted to controll more than one bridge.
Maybe a solution with a 150v and controlled current source right after the dc/dc and then connect this to the h-bridge. Does anyone have an idea how to do this source current, providing current to the h-bridge?
Idea:
