Gyroscopic mice
Discussion in 'General Electronics Chat' started by Voltboy, Aug 1, 2007.
  1. Voltboy
    Thread Starter Active Member
    Jan 10, 2007
    197
    Hello...
    I am trying to use the gyroscopic mouse circuit for a little project (which dont have nothing to do with my question)
    Im talking about the mouses that have a ball, and a shaft whuch turns let pulses form the infrared diodes to the infrared receptors..
    There is one capacitor in the circuit.. and i just dont get why would its there.. and another things.. the cable is a PS/2 so its connected in VDD (which supossed is the volts in), the CLK (which i think transfers the pulses of the clicks) and DAT and GND.. i know GND if for the ground of PC but whats the DAT for??
    thanks
    Yoda
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Can you post the schematic of the circuit?
    VDD is your logic high voltage, as a compliment to GND. DAT could be the data bus - but again without a schematic this is just a speculative guess.
    Dave
  3. Gadget
    Distinguished Member
    Jan 10, 2006
    613
    No gyroscope involved. What you are describing is a standard serial or PS2 mouse. It uses a rotating wheel with slots to interrupt 2 IR interrupters in the x and another setup for the y directions. A dedicated chip interprets the 2 sets of "out of phase" pulses from each interrupter as mouse direction and speed, and sends this information in Serial form down the Data line. The Clock is constant and used to synchronise the data. VDD is normally 5 volts, but is often regulated in the mouse itself (explaining the cap).
  4. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    In some modern designs this is moving towards 3.3V and 1.8V.
    Dave
  5. Voltboy
    Jan 10, 2007
    197
    ok srry.. i thought this was called gyroscopic..
    but Dave I know that if i had a shcematic i could interpret.. buts thats the problem i dont have a shcematic i just have the mice but Gadget in thsi mice there is no chip to interpret the pulses, there are only 3 diodes, 3 recievers 3 resistors, one capaciotr and switches for the click.. :confused:
  6. Papabravo
    Feb 24, 2006
    10,340
    1,850
    What is the part you are calling a receiver? That term conveys no useful information to me.
  7. JoeJester
    Apr 26, 2005
    3,394
    1,213
    Can you post a picture of the circuit board? ... both top and bottom.
    This attachment is one of my older mice.
  8. mrmeval
    Jun 30, 2006
    833
