Gyros and accelerometers
Discussion in 'General Electronics Chat' started by tornado151, Aug 22, 2010.
  1. tornado151
    Apr 15, 2010
    34
    What is the difference between a gyro and accelerometer?
    I believe that they can both detect rotation?
    Which is the most accurate?
  2. hspalm
    Feb 17, 2010
    201
    8
    An accelerometer detects acceleration force, and does not have to be multi-dimensional. This means it can detect something like how hard you swing or "accelerate" a device, like in a nintendo wii control. A gyroscopes main purpose is what you said, to detect which dimension a device is leaning, sort of speak.
    tornado151 likes this.
  3. tornado151
    Apr 15, 2010
    34
  4. big5824
    Jul 15, 2010
    9
    gyros detect the rate of change of angle, which you then integrate to find the angle.
  5. marshallf3
    Jul 26, 2010
    2,358
    201
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Take a look at MEMS motion sensors. A couple of example part numbers are LIS3L06AL, LIS33DE, both can sense motion in all 3 axis. You'd need to use a microcontroller to interface with them.
    If that looks too difficult, Radio Shack stores generally stock a 2-axis accelerometer for around $33: http://www.radioshack.com/product/index.jsp?productId=2909788
    You'll still need a uC or other circuitry to get the data out of it.
    The missile rate gyro Marshallf3 linked to could work, but be aware that you will need one complete circuit & gyro per axis to be tracked, and they will have to be physically linked together.
  7. BMorse
    Sep 26, 2009
    2,675
    234
  8. tornado151
    Apr 15, 2010
    34
  9. BMorse
    Sep 26, 2009
    2,675
    234
    If you want to directly connect it to a PC you will need a I2C to Serial adapter or similar circuit (similar to these >> http://www.i2cchip.com/).... since the module requires a I2C connection to a processor...
    B. Morse
  10. tornado151
    Apr 15, 2010
    34
