Discussion in 'General Electronics Chat' started by Timothy, Sep 27, 2003.
  1. Timothy
    Thread Starter Guest
    Hi every body i have a question that what is the limit of voltage and current on which gyrators can work. Can we build gyrators which can work on 1000 volt. What will they do. I think they will make 1000 volt into 0.001 volt i.e 1/1000, the inverse of 1000 volts. Thank you.
  2. Ardianwardhana
    Apr 2, 2009
    Gyrator's voltage limits mainly affected by active device's voltage range, for op-amp based, it would no higher than 30V.
