It wouldnt let me reply to the older threads about gyrators.
Okay, I was reading a tutorial about op amps and their basic use in circuits and I came upon something called a gyrator. From what I gathered from these forums it is an op amp connection that reverses the effect of the capacitor. So instead of causing a sudden current spike and gradual voltage rise/current fall we get the reverse effects.
I found a simulator about the gyrator too.
http://www.falstad.com/circuit/e-gyrator.html
I did make some notes. I am referring to the falstad circuit in the text below.
Since the op amp has a feedback it tries to hold the inputs at the same level and since the output is connected straight to one of the inputs it shares their voltage aswell. So all the three op amp connectors share the same voltage at all times.
When the voltage changes polarity the cap and 20kohm resistor share the voltage to some extent. The voltage on the noninverting input is the same that is over the 20kohm resistor. As the cap charges that voltage is becomes lower and lower. That also means that the other input and the output will have that same voltage. Starting from a higher value at the rising and falling edge and falling to near zero volts.
But the thing I dont understand is why the current rises as the voltage falls? The 1kohm resistor the current has to go through does not change.
So how does this happen?
I can understand that the max amperage comes from I = U/R and that is 5v/1000ohms tops, 5milliamps that is. But at the time the op amp outputs that 5 milliamps the voltage it outputs is at the lowest.
Oh! I just might have gotten it now as I type this. The op amp output has to push against the input voltage that is of the same polarity at the 1kohm resistor. So, the current equals (input wave)-(op amp output) / 1kohm ?
In the beginning when the cap has not yet charged this will be lower and going towards 5volts load the amperage will increase towards the maximum possible. This is limited by the op amp current sinking/ sourcing capabilities?
