guys can you help me plz ....
Discussion in 'Homework Help' started by salem2200, Nov 16, 2014.
  1. salem2200
    Nov 16, 2014
    guys can you help with this question ....
    when you are about to measure the current flowing into a motor rated at 50 A , you realize that the ammeter you are using has a rating of 1 amp maximum only ( internal resistance of the ammeter is 50 ohm ) . suggest what you would do to use the ammeter to measure the current flowing in to the motor ?
    Moderators note: reduced size as large fonts are like shouting
  2. shteii01
    Feb 19, 2010
    3,500
    511
    Current divider.
    salem2200 likes this.
  3. crutschow
    Mar 14, 2008
    13,496
    3,373
    A current divider is a resistor placed in parallel with the meter so that a portion of the circuit bypasses the ammeter. So if you want to change the 1A meter into a 100A meter you would select a resistor value such that 99A flows through the parallel resistor while 1A flows through the ammeter. I will leave the calculation of that resistor value as an exercise for the OP.
  4. bertus
    Administrator
    Apr 5, 2008
    15,801
    2,387
    Have a look on google for "shunt resistor"
    Bertus
  5. salem2200
    Nov 16, 2014
    Thanks :) that was very useful ;)
