guitar tuner
Discussion in 'The Projects Forum' started by architjain_17, Feb 20, 2010.
  1. architjain_17
    Feb 20, 2010
    10
    i want to make a guitar tuner by self.i know the logic that the project needs,ie, accepting sound, filtering the frequency and then controlling LEDs through the filtered signal.please help me make it.i just want to accepts one frequency of 440 hz.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. avgeris89
    Feb 20, 2010
    find a frequency to voltage intergraded circuit and measure the output voltage when you have 440Hz input.
    then put a comparator circuit. on the one input connect the output of the intergraded circuit and on the other input put the voltage that you find before with a voltage divider.
    it should work.
    if you need more help just email me. <snip>
  4. avgeris89
    Feb 20, 2010
    sorry my friend i have a mistake on the circuit that i told you.
    at the output of the comparator you should connect an LED but it will turn on when you have frequency equals to 440Hz or higher.
    simpler you can just connect the output of the frequency to voltage intergraded circuit to an analog volt meter and to see the voltage on 440Hz, then mark this point and you will know every time when you play 440Hz. also you can mark the voltages on the other notes that you play. so you will have a guitar tuner for all the notes.
  5. nomurphy
    Aug 8, 2005
    567
    12
    You do realize that 440Hz is the 'A' (fifth fret) above the open 1st string 'E'?
    The open 'A' fifth string is two octaves down at 110 Hz.
