I have been working on this project for a custom guitar hero controller for myself. For the 5 buttons on the frets I am trying to use a "finger touch activated switch" which I got from here http://www.discovercircuits.com/PDF-FILES/fingersw.pdf I have the parts and tested it with my power suppy and a LED and it works exactly how I want it to. But when I am trying to connect it to the circuit board taken out of a playstation controller is where I am getting stuck at. The circuit on the controller uses 5 wires all having 3.4VDC and then the common GND. So when the you want the certain button pushed the 3.4volts touches to the GND and the game see's that button is pushed. I've tried the finger activated switch and it will work at 3.4volts but how can I connect it to work with the controller circuit???
