I finally finished this project I began late last year. I was in need of some sort of overdrive/distortion pedal because I have a couple of single-channel tube amps that don't begin distorting nicely unless turned up very loud, which isn't always practical. I had some old germanium transistors in my parts bin that I pulled out of a radio or something over 30 years ago when I was a kid, so I figured I'd put them to use.
The pedal's design employs two stages, the first being an emitter-follower acting as a buffer and the second being a Class-A amp with a couple of germanium diodes (new) that can be switched on and off for clipping the signal. The "gain" knob isn't working quite as I hoped. Yes, when turned all the way up, the gain does increase, but turning it all the way down doesn't even come close to killing the signal. I guess there's still plenty of gain provided by R11.
Attached are a couple photos and a 5 minute clip demonstrating the sound. Thanks for the help previously received. I'll be back for more soon.
