Guidelines for a super stable linear PSU?
Discussion in 'General Electronics Chat' started by TheLaw, Jan 16, 2011.
  1. TheLaw
    Sep 2, 2010
    228
    Hello everyone,
    I'm trying to build a super stable power supply. I've been roaming the internet for just about an eternity but I can't find exactly what I am trying to figure out.
    My question is mostly about capacitors.
    What kind of capacitors do I use? Where in the circuit do I use the capacitors? What value capacitors is best?
    This section is me asking every possible question about power supplies and capacitors. Reader beware.
    So to explain that further. I should have a high value electrolytic before the voltage regulator. Should any other type of capacitor be used before the regulator? I've heard a ceramic should be on the input and output of a regulator. Should I use a metalized polypropylene film instead? Or strictly ceramic?
    On the secondary side of the voltage regulator, I should have another high value electrolytic. What other types of capacitors should be there? More films? Ceramics? What do different types of capacitors do? How do I determine the value? What order should the capacitors be in? Electrolytic, film, ceramic? Does it matter?
    Okay, I recognize that I just asked about 6,000 questions. That's just me belting out all of my problems that I've been trying to figure out.
    If you can answer just one or two, I'd be very happy. Please don't be bewildered by my questions.
    I appreciate it.
    Thanks.
  2. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,388
  3. radbrad
    Jan 17, 2011
  4. timrobbins
    Aug 29, 2009
    318
    16
    TheLaw, it seems that you're really just after a standard regulated power supply from a generic constant voltage regulator (aka 7805), and need to read thoroughly the application notes available from manufacturers of the regulators. Or do you have some super special application?
    Ciao, Tim
  5. R!f@@
    Apr 2, 2009
    8,791
    771
    What's the difference between a Regulated PSU and a stable PSU or/and a Super Super stable PSU.
    I dunno what the OP wants but what I built is far better than anything I can buy here.
  6. TheLaw
    Sep 2, 2010
    228
    Hehe. I just meant...More stable than the average regulated linear supply.
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You might look at the uA723. It's been around for quite awhile. Much better than your typical LM317 regulator.
  8. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,388
  9. TheLaw
    Sep 2, 2010
    228
    Wow, those look lovely. Too bad they can't push too much current. For a 5V regulator, is the Texas Instruments TL780-05 better than a standard LM7805. By specification, it seems to have better line/load regulation, but I can't be sure.
  10. TheLaw
    Sep 2, 2010
    228
  11. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    What do you mean by stable? The 7805 isn't unstable.
  12. TheLaw
    Sep 2, 2010
    228
    Stable probably wasn't the right word. I mean: Ultra low ripple and good voltage regulation.
  13. TheLaw
    Sep 2, 2010
    228
    And where do you find these application notes that have the component selection guides? These voltage regulator datasheets don't include much of that. I've seen component selection guides on switching regulators and op-amps, but none on linear regulators.
  14. R!f@@
    Apr 2, 2009
    8,791
    771
    U don't seem to understand.
    The IC regulates and the transistor handles any current u desire.
  15. TheLaw
    Sep 2, 2010
    228
    Oh you are <snip> right. I was about to say....this beautiful regulator with 150uA max? What a shame.
    I understand it now...Hmm....It's a possibility.
  16. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    A stock 7805 is a 1A regulator, the 78S05 is 1.5A
    What do you need ultra low ripple for? What are you powering?
  17. TheLaw
    Sep 2, 2010
    228
    It's just a theoretical question. I don't really have anything to power as of now. Maybe a small amp or something later on.
  18. kubeek
    Sep 20, 2005
    4,689
    806
    That greately depends on what you mean by low ripple. For a 5v regulator it could be 10mV for someone, 1uV for another.
    Also the speed at which it can regulate makes a difference. You could want 100ns settle time after a severe change in current, or you could do with much slower response.
    So lets get some practical numbers in here, what amount of regulation do you need?.
  19. tom66
    May 9, 2009
    2,613
    214
    Generally you shouldn't worry about any less than 20mVp-p ripple on a 5V supply as it's not going to make a significantly audible noise.
  20. Wendy
    Mar 24, 2008
    20,772
    2,540
    Most IC regulators (such as the 7805) are very good. Look at the data sheet, going from memory I believe it is 60db, which is in the nanovolt region. As long as the ripple going into the regulator is above the power up range of the regulator you should have nothing to worry about.
