Guidance needed for an auto power off NOT using a relay circuit
Discussion in 'The Projects Forum' started by enveetee, Dec 6, 2009.
  1. enveetee
    Dec 1, 2009
    5
    Hi
    I have a working circuit for my project which runs off a Lithium Polymer battery. The battery has a nominal voltage of 9.9V and the circuit draws up to 2 amps. (It's a heat regulator circuit for a pair of gloves)
    I'm looking for guidance on how to make a circuit which will disconnect the heater circuit when the LiPo battery voltage reaches about 9V.
    I'm quite happy using a dedicated voltage monitoring chip (MAX8211 or MAX 8212) and a relay to disconnect both the monitoring circuit and heater regulator circuit, however I was wondering if it was possible to use a MOSFET and if so, what components should I use.
    Cheers for any advice, tips or even actual circuits!
    Nigel
  2. bluebrakes
    Oct 17, 2009
    245
    7
  3. BMorse
    Sep 26, 2009
    2,675
    234
    or if you are going solely on voltage levels, use an LM339 or another opamp, so you can set your upper and lower thresholds.... and use a Mosfet to cut the power off/on, since the relay would drain the battery more....
  4. KMoffett
    Dec 19, 2007
    2,584
    234
    Nigel,
    I think one of those (with it's associated resistors), and an N-channel MOSFET...like a IFRZ34N with a 1K pullup resistor...will work.
    Ken
  5. enveetee
    Dec 1, 2009
    5
    Have I missed something
    Did you read my post? No mention of time or temperature.
    Nigel
  6. enveetee
    Dec 1, 2009
    5
    Ken, how much current does the IFRZ34N draw in it's non-conducting mode?
    With a relay, once it is de-energized, I can be confident that the current drawn will be zero. I need to be sure of this because once the IFRZ34N is not conducting, my user could leave the circuit connected and eventually damage the LiPo
    Nigel
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You can determine the leakage current of the IFRZ34N via it's datasheet.
    It will likely be substantially less than the LiPo's own internal leakage current.
    Your relay idea will work, but the battery drain will be substantial, and the relay will be making/breaking a connection with a fair amount of current. You'll need to use a relay rated for 3x the current to get at least a reasonable life span from it.
    Here's an idea using an N-ch MOSFET with the trip voltage set by a micropower Zener diode. C1/R5 should really be replaced by a N.O. momentary switch to provide a reset; otherwise if the consumer doesn't manage to connect the battery without "bouncing" the connections, it will not turn on by itself.
    Leakage current will be under 1uA, except for the selected MOSFETs' leakage current.
