GUI Touch-Screen interface
Discussion in 'General Electronics Chat' started by hunterage2000, Nov 1, 2012.
  1. hunterage2000
    Thread Starter Active Member
    May 2, 2010
    402
    Im not sure the questions I should be asking but I want to create an iphone type application that can be controlled by a touch screen.
    This GUI will be used to control a hand grapper that moves in X,Y,Z coordinates in increments of 1mm.
    Can anyone suggest how I can make this happen?
  2. panic mode
    Oct 10, 2011
    1,328
    305
    which part is the problem?
  3. hunterage2000
    May 2, 2010
    402
    not really a problem just I dont know if such a GUI exists to create your own touch screen apps.
  4. vpoko
    Member
    Jan 5, 2012
    258
    47
    There are many. Android, Windows 8, qt, etc. What hardware and OS would you be using?
  5. hunterage2000
    May 2, 2010
    402
    I will be using a microcontroller to control a few stepper motors to move in x,y,z coordinates.
  6. panic mode
    Oct 10, 2011
    1,328
    305
    do it in stages, first control it from buttons tied to microcontroller inputs.
    when this is working satisfactory, then explore how to communicate with cicrocontroller using some other device such as iphone.
    once this works, use GUI to read and write from microcontroller.
    you can use read access to display status such as position, speed etc.
    you can use write access to send control signals.
    they can be mapped and used instead of local buttons (or along with them).
  7. hunterage2000
    May 2, 2010
    402
    So can an iphone be used as a touch screen controller connected through a microcontroller? Can you tell me what I would need i.e software for the application and cable/or wireless connection to and from the MC?
  8. vpoko
    Member
    Jan 5, 2012
    258
    47
    The phone could be connected as a USB device to the microcontroller (serving as a USB host) using an appropriate chip. Then you'd need to write software for your iPhone that can interact via the USB port with a connected host. It's not a turnkey solution, but when is it with this stuff?
  9. panic mode
    Oct 10, 2011
    1,328
    305
    this is your project and doing research is part of it.
    how do you plan to use the iphone and what is already integrated in it?
    do you want to use it as wired or wireless remote?
    if wired, what options are there? usb?
    if wireless, what options are there? using it as a phone would require microcontroller to have access to phone line as well. if there is any other port such as Bluetooth or infrared or whatever, your microcontroller will again need the same thing.
    once you have chosen avenue, you need to walk it. get resources like documentation, sdk etc and do it one little step at a time. plan before you execute.
    if there are mems like gyro, accelerometer etc, this can open new possibilities in terms of control inputs, it does not need to be just touch.
