GUI for matlab code
theertham
Joined Apr 28, 2012
26
hi
can anyone help me to develop GUI(graphic user interface) for my matlab code for retinal image analysis.my code is used to detect optic disc and exudate in retinal images using contour techniques
Code:
clc
clear all
close all
%% Read images.
for count = 32:32
    name = ['Images 1\' int2str(count) '.tif'];
    img = imread(name);
    res_img = imresize(img,[256 256]);
    gr_img = rgb2gray(res_img);
    figure(1),imshow(gr_img),title('Input Image')
    pause(0.2)
    h = fspecial('unsharp');
    filt_img = imfilter(res_img:),:,2),h);
    h = fspecial('disk',4);
    filt_img = imfilter(filt_img,h);
    figure(2),imshow(filt_img),title('Filtered Image')
    pause(0.2)
    bw = im2bw(filt_img,0.43);
%     figure(3),imshow(bw),title('BW Image')
%     pause(0.2)
    se = strel('disk',5);
    BW_erod = imopen(bw,se);
    BW_dil = imdilate(BW_erod,se);
%     figure(4),imshow(BW_dil),title('Optic Disc')
%     pause(0.2)
    [L num] = bwlabel(BW_dil);
    if num == 0
%         disp('1:Optic Disc - Not Spotted')
        newstats = [];
    elseif num > 1
        newstats = [];
        stats = regionprops(L,'basic');
        for count2 = 1:length(stats)
            if ((stats(count2).Centroid(1) >= 75 && stats(count2).Centroid(1) <= 110) || ...
                    (stats(count2).Centroid(1) >= 160 && stats(count2).Centroid(1) <= 190)) && ...
                    (stats(count2).Centroid(2) >= 110 && stats(count2).Centroid(2) <= 145)
                newstats = stats(count2);
            end
        end
    else
        if stats.Centroid(2) < 100 || stats.Centroid(2) > 150
%             disp('3:Optic Disc - Not Spotted')
            newstats = [];
        else
            newstats = stats;
        end
    end
    if ~isempty(newstats)
        if newstats.BoundingBox(3) < 50
            newstats.BoundingBox(1) = newstats.BoundingBox(1) - ...
                                    (50 - newstats.BoundingBox(3))/2;
            newstats.BoundingBox(3) = 50;
        end
        if newstats.BoundingBox(4) < 50
            newstats.BoundingBox(2) = newstats.BoundingBox(2) - ...
                                    (50 - newstats.BoundingBox(4))/2;
            newstats.BoundingBox(4) = 50;
        end
        if newstats.BoundingBox(3) > 100
            newstats.BoundingBox(3) = 100;
        end
        if newstats.BoundingBox(4) > 140
            newstats.BoundingBox(2) = newstats.BoundingBox(2) + 20;
            newstats.BoundingBox(4) = 110;
        end
        region = imcrop(gr_img,newstats.BoundingBox);
        uiloc = find(any(region<3));
        if isempty(uiloc)
            ROI = region;
        elseif uiloc(1) == 1
            ROI = region:),uiloc(length(uiloc))+1:end);
        else
            ROI = region:),1:uiloc(1)-1);
        end
%         figure(5),imshow(ROI),title('Input to Contour detection')
%         pause(0.5)
        imwrite(ROI,'ODisc.tif')
        [ubin c xarr yarr cmat wdt] = test_activecontour('ODisc.tif',0,6);
        pause(1)
        %% Applying Correlation to find segmented region..
        disp('Computing Correlation...')
        val = zeros(size(gr_img,1)-size(ROI,1),size(gr_img,2)-size(ROI,2));
        for i = 1:size(gr_img,1)-size(ROI,1)
            for j = 1:size(gr_img,2)-size(ROI,2)
                portion = gr_img(i:i+size(ROI,1)-1,j:j+size(ROI,2)-1);
                val(i,j) = corr2(ROI,portion);
           end
        end
        [r,c] = find(val == 1);
        rect = [c r size(ROI,2) size(ROI,1)];
        figure(7),imshow(gr_img),title('Region Segmented')
        rectangle('Position',rect,'EdgeColor','g')
        pause(1)
        if newstats.Centroid(1) < 128
            rem_reg = gr_img:),round(newstats.BoundingBox(1)+60):end);
        else
            rem_reg = gr_img:),1:round(newstats.BoundingBox(1)));
        end
%         figure(8),imshow(rem_reg),title('Remaining Region')
%         pause(0.5)
%         pos = find(all(rem_reg'<3));
%         diff_pos = diff(pos);
%         sep_point = find(diff_pos > 1);
%         rem_reg(pos(sep_point+1)-1:pos(end),:) = [];
%         rem_reg(pos(1):sep_point+1,:) = [];
        rem_reg(217:end,:) = [];
        rem_reg(1:40,:) = [];
        rem_loc = find(any(rem_reg<3));
        if isempty(rem_loc)
            rem_ROI = rem_reg;
        elseif rem_loc(1) == 1
            rem_ROI = rem_reg:),rem_loc(length(rem_loc))+1:end);
        else
            rem_ROI = rem_reg:),1:rem_loc(1)-1);
        end
%         figure(9),imshow(rem_ROI),title('Remaining region to Contour Detection')
%         pause(0.5)
        imwrite(rem_ROI,'RemR.tif')
        [ubin c xarr yarr cmat wdt] = test_activecontour('RemR.tif',0,10);
        pause(2)
    else
        disp('Optic Disc - Not Spotted')
    end
%     close all
end
Moderators note: used code tags
theertham
Joined Apr 28, 2012
26
yes sir.but i need two pushbuttons to upload input and output.also i need two axes in order to show the input,region of segmentation and the output.I am not able to edit the programe in the m file editor
kitto326
Joined Aug 21, 2009
Dear theertham,
mark your code with comments and do sort it with required GUI components. I am pretty much sure you'll do it by your own. MATLAB GUI is not that difficult.
Give it a try or come back with sorted and commented code.
vortmax
Joined Oct 10, 2012
102
I've done quite a bit of matlab GUI hacking.... there is too much to relay in a post here. I will give you some hints that I think will help you along.
Guide will create a .fig file and a .m file. The m file holds the code, the fig file hold the graphics objects.
Use guide to create the layout of your GUI. Place a single axes object and two buttons. Use the property editor to name them something identifiable. Save it and switch over to the m file. This file contains a list callbacks that execute on GUI events, such as button presses.
In the GUI opening function, you can handle the initialization. If you want to open the gui with a command such as openGUI('file_to_read'), then this would be where you read the file, do initial processing and plot the image. These parameters are passed in using the varargin struct...if you don't know what that is, look it up.
You will want to pull out the important parts of your script and convert them to functions that perform very specific actions....for instance reading data from a file and converting it into a usable form...or writing data to a file...or applying some filter....or plotting the data, etc. How many pieces you break it into depends on how you reuse those functions and what stuff you need to change. For instance, you could have one function that reads the data and plots it every time you change a setting, or you could have one function to read the data and store it in a variable, then call a second plot function every time a parameter changes.
Once you have your functions written, then decide on the interaction. When a button is pressed, the callback is fired...this function should be populated in the m file already. The handles structure is what allows you to persist data in the figure. For instance, when you read data from a file, you would write it to the handles structure, so later functions can access the data without reloading it. The handles structure also contains the handles to all of the graphic objects, which allow you to edit and modify them directly. For instance, you can grab the current position of the existing axis, and use that to create a second axis object that overlaps the first exactly. Do this in your opening function, and you now have 2 stacked axes. You can specify the axes handles in plot commands like image, imagesc, plot, scatter, etc... so plotting overlays in your plot function are as simple retrieving the axes handles from the handles struct and passing them to your plotting functions. E.G.
Plot_callback(handles)
imagesc(handles.data,'Parent',handles.lowerAxes');
scatter(handles.topAxes,handles.POI:),1),handles.POI:),2));
end
notice that imagesc and scatter handle the axes handle differently.
To handle the file IO, look into uigetile and uiputfile. These will open a window that lets you select a file and will return the file name and path (they don't actually do anything to the file). Once you have the path and name, then you can use load, imread, save, imwrite, or whatever you want to actually read/save the file. the fullfile function will help put the path and name together.
vortmax
Joined Oct 10, 2012
102
i told you how to do that.....
make two buttons. For the 'read' data button, use uigetfile in the call back to let the user select the file. Uigetfile returns the path and file name...use those and imread or load or whatever to read the file, then apply whatever preprocessing you do to it and store it in the handles struct.
for the 'write' data button, use uiputfile in the callback to get the path info for the file to write to. Then format your data however you want it, and use save, imwrite, etc to save the data.
John_2016
Joined Nov 23, 2016
55
Hi Unasathyananth
this is John BG jgb2012@sky.com
after a few small changes to avoid the emojis corrupting the code you posted,
your code started running, showing input and filtered images, but then
where is the support function test_activecontour?
1st call in line 87
Please post MATLAB code in .zip attachment, .m file extensions not valid for uploads yet.
