Hello, I bought LED light controller that has (I think) a Pic chip,
now the chip info has been sanded off. so it makes it harder to clone a china stuff.
But a little in on the pinouts,
it is 14 pins, 3 buttons that each shorts to ground to 3 pins on the chip.
Each button changes the patterning/code.
all the PICAXE chip that are 14 Vcc and Gnd are 1 and 14.
But this chip is not that way,
Pins
1 - N/C
2 - N/C
3 - N/C
4 - Vcc 5v connected to pin 7
5 - in from GND to change code mode 1
6 - in from GND to change code mode 27 - Vcc5v connected to pin 4
8 - in from GND to change code mode 3
9 - N/C
10- N/C
11- GND
12- N/C
13- pin out to Transistor 1
14- pin out to Transistor 2
If I can find the right data sheet for this I can try to read the chip and re-wright the chip to do what I want each pin to do.
I have played with PIXACE Chips like the 08M 18M, I have made Ham Beacons to play Morse Code, Repeater Controllers, etc...
Thanks for your time. Sam
Pins
1 - N/C
2 - N/C
3 - N/C
9 - N/C
10- N/C
11- GND
12- N/C
