GSM Module Issue
Discussion in 'Wireless & RF Design' started by Embed, Jan 21, 2014.
  1. Embed
    Jan 21, 2014
    Hi Friends,
    The following is the initialization I am doing on fibocom G610 module
    String("AT&F0\r"); //Master Reset
    Delay_62ms();
    String("AT\r"); // Basic Command ATTENTION
    Delay_62ms();
    String("AT+CMGF=1\r"); // Text Mode
    Delay_62ms();
    String("ATE0\r"); // Echo OFF
    Delay_62ms();
    String("AT+CNMI=3,1\r"); // Receive Unsolicited Interrupt Enable
    Delay_62ms();
    String("AT+CMGD=2,4\r"); // Delete All Messages With No Conditions
    Delay_62ms_Caller(15);
    When i send a message as "STS"
    Ascii Value of S is 53
    Ascii Value of T is 54
    The module is reading the message body as following 6 Byte
    array_data[1]=0x35 '5'
    array_data[2]=0x33 '3'
    array_data[3]=0x35 '5'
    array_data[4]=0x34 '4'
    array_data[5]=0x35 '5'
    array_data[6]=0x33 '3'
    The remaining data that is date, time and message sender number are in text format only, only the message body as above.
    Thank You, Good Day:)
