GSM modem interfacing to AT89C51
Discussion in 'Embedded Systems and Microcontrollers' started by amit251291, Jan 11, 2013.
  1. amit251291
    Dec 30, 2012
    Can you please tell me how to interface GSM modem (sim 300) to microcontroller (AT89C51)to send sms?
    I need assembly program for the same..
    I have prepared my own but it is not working:
    here it is:
    Code ( (Unknown Language)):
    1. ORG 0000H
    2.         MOV TMOD,#20H               //TIMER 1, MODE 2
    3.         MOV TH1,#-3                //9600 BAUD RATE
    4.         MOV SCON,#50H            //8 BIT, 1 STOP, EN ENABLED
    5.         SETB TR1
    6.
    7.         MOV DPTR,#MSG1
    8.         ACALL H1
    9.         ACALL DELAY
    10.         MOV DPTR,#MSG2
    11.         ACALL H1
    12.         ACALL DELAY
    13.         MOV DPTR,#MSG3
    14.         ACALL H1
    15.         ACALL DELAY
    16.         MOV DPTR,#MSG4
    17.         ACALL H1
    18.         ACALL DELAY
    19.         MOV DPTR,#MSG5
    20.         ACALL H1
    21.         ACALL DELAY
    22. STAY: SJAMP STAY
    23. H1:      CLR A
    24.         MOVC A,@A+DPTR
    25.         JZ B1
    26.         ACALL SEND
    27.         INC DPTR
    28.         SJMP H1
    29. B1:
    30.         RET
    31. SEND:     MOV SBUF,A
    32. H2:     JNB TI,H2
    33.         CLR TI
    34.         RET
    35. DELAY:  MOV R3,#50H
    36. HERE2:  MOV R4,#50H
    37. HERE:    DJNZ R4,HERE
    38.         DJNZ R3,HERE2
    39.         RET
    40.
    41.
    42. ORG 300H
    43. MSG1: DB "AT",0DH
    44.       DB 0H
    45. MSG2: DB "AT+CMGF=1",0DH
    46.       DB 0H
    47. MSG3: DB "ATE=0",0DH
    48.       DB 0H
    49. MSG4: DB "AT+CMGS=",'"8149111111"',0DH
    50.       DB 0H
    51. MSG5: DB "TEXT",0X1A
    52.       DB 0H
    53.
    54.       END
    connections:
    GSM modem has following on-board connections:
    MAX232----->> RS232 (Female connector)
    pin 7 ---> Pin 2
    pin 8 ---> Pin 3
    So i have done following connections after this:
    RS232 (Female connector) --->> RE232(PCB male connector ) ( This o did because it was difficult to take connections from on-board Female connetor)
    I took out following pins from RS232 male connector and connected to microcontroller:
    RS232(PCB male connector ) ---> AT89C51
    Pin 2 --> Pin 11
    Pin 3--> Pin 10
    Pin 5 Grounded.
    Rest AT89C51 connetions:
    Crystal oscillator 12 Mhz.
    EN (Pin 31) -VCC
    Pin 40-- VCC
    Pin 20-- Gnd
    Are these connetions are correct??
    why my program is not working ??
    can any one tell me assembly program to interface the same?
  2. tshuck
    Oct 18, 2012
    3,531
    675
    How about supplying a schematic. That will allow us to be able to see your connections instead of read about them.
  3. athgen
    Jan 8, 2013
    i think . can help you
  4. amit251291
    Dec 30, 2012
    here is my circuit diagram...
    please tell me where i am going wrong :|
