Grounding question
Discussion in 'General Electronics Chat' started by dangar9, Mar 13, 2012.
  1. dangar9
    Mar 13, 2012
    sir i am in trouble that after entering in ground how electron reach to its main source as ground is different at different place and hoe we can judge that at a particular point it is conductor or insulator inside the ground?
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Welcome to AAC!
    A thread belongs to the OP (original poster). Trying to take over someone elses thread is called hijacking, which is not allowed at All About Circuits. I have therefore given you a thread of your very own.
    This was split from Electronics AC/DC + Logic Cheat Sheets (Final Edition)
  3. crutschow
    Mar 14, 2008
    13,501
    3,375
    I'm not sure I complete understand your question, but a ground potential is only different due to any current going through the ground impedance between any two ground points. Normally you attempt to keep all points on a ground at the same potential by keeping this impedance as low as possible, such as by using a solid copper ground plane on a circuit board, which minimizes both inductance and resistance.
    I don't know what you mean by insulator inside the ground. :confused: Of course a ground is insulated from the signal and power lines in a circuit, if that's what you are referring to.
