In encoder connection we use Twisted pair with shield cable.And in connection we ground the Shield at both the ends(Drive side as well as encoder side). WHY? Want to knw abt it...Because some one telling that we connec the shielding at one end.
For which frequency range is the shield an efficient antenna is still an open question.Some people connect just one end in an effort to avoid ground loops.
However, they have never had to deal with EMC. If you connect the shield at only one end, you have just created an antenna which can radiate high frequencies or conduct into your box.
I deal with shielded Primary Leads on aircraft magnetos, and shielded spark-plug leads. The goal of shielding is to prevent the wire inside the shield from radiating. If you only ground the shield at one end on a magneto P-lead, the open end radiates into the VHF range and clobbers the radios... If a spark-plug lead becomes ungrounded at one end, you hear ignition noise in the VHF receivers.Some people connect just one end in an effort to avoid ground loops.
