grounding for generator?
Discussion in 'General Electronics Chat' started by Truc Do, Dec 3, 2014.
  1. Truc Do
    Dec 3, 2014
    We do have generators for construction sites. My question is "should we ground the generators for safety reasons?" as I think when the generator is on "float" the leakage current cannot go back to its source and it is safer.
    Appreciate your explanation and clarification.
    Thanks,
    Truc Do
  2. alfacliff
    Dec 13, 2013
    2,449
    428
    a ground would be better than none for safety. how can you guarentee nothing will ground wrong?
  3. #12
    Nov 30, 2010
    16,673
    7,320
    Let me say that in a longer way: If YOU ground it, everybody will know it's grounded and damaged cables will blow a fuse. If you leave it ungrounded, your crew will only find out a cable got damaged after it hurts somebody.
    A welder has no ground, but its cables are short enough to be aware of at all times. A construction site is too big and too busy for anyone to know every wire is not damaged by yesterdays work crew.
