You'll most likely be appalled at the ridiculous simplicity of this problem,
but I'm entirely new to this, so please forgive me
I need to replace an AC/DC converter within a switch.
The new converter has 5 connectors:
AC/L AC/N Ground VDC5+ VDC5-
1. Question:
Am I to connect the ground of the converter to the same ground
which is connected to the switch's casing?
2. Question:
The switch has 3 cables running to the converter.
Red, black and white.
I guess red should be VDC5+, white VDC5- and black is the ground.
Is it ok to attach the black cable to the same ground as the converter?
Thanks for your help.
1. Question:
2. Question:
