Grounding DC
Discussion in 'General Electronics Chat' started by edgetrigger, Dec 19, 2010.
Thread Status:
Not open for further replies.
  1. edgetrigger
    Dec 19, 2010
    133
    19
    Can the negative terminal of the bridge rectifier connected to an A/C mains(either 120v/220v) be grounded( connected to earth).
  2. nerdegutta
    Dec 15, 2009
    2,565
    805
    Don't think so.
    Not like that.
    Do you have a schematic?
  3. thatoneguy
    Feb 19, 2009
    6,357
    718
    It is not recommended. If there is a wiring fault, your DC ground could be the AC hot line.
    Leave the DC ground common to the DC circuit, but isolated from the AC line.
  4. edgetrigger
    Dec 19, 2010
    133
    19
    Just a four diode bridge, with the negative output point of the bridge connected to earth pin of the mains.
    I think it will short the voltage during negative half cycle, am not sure.
  5. nerdegutta
    Dec 15, 2009
    2,565
    805
    I would do what thatoneguy said, isolated from the mains.
    Welcome to the forum, btw. :)
  6. edgetrigger
    Dec 19, 2010
    133
    19
    thanks for welcoming.
    but not clear why is the isolation required. Not for the safety issue, can this be connected. Wont there be a substantial voltage during the negative half cycle of the A/C. wont the grounding short this negative half cycle. My oscilloscope is down, just was trying to be analytical.
  7. #12
    Nov 30, 2010
    16,671
    7,318
    Looking at the schematic in my mind, I say you will blow a fuse, instantly. Can we see the schematic that is presently in your mind?
  8. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You are using a transformer for isolation? If so, it should be utterly obvious that a connection to the primary side does away with that isolation.
    If this is simply rectifying the line voltage, it is a practice we are against, as it is so unsafe.
  9. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You must use a transformer or some type of inductive coupling to isolate the output from the mains. Without such isolation, your circuit won't be safe.
    If your rectifier circuit is on the primary side of a switching regulator, you don't use the ground wire; you use the neutral wire. The secondary side and enclosure should be connected to the ground wire.
  10. PackratKing
    Jul 13, 2008
    850
    216
    I have repaired a number of professional-type floor polishing machines, that plug in to 120vac, hot lead through a switch to a-c inputs of a large 50 amp monolithic bridge rectifier - no heatsink other than the motor end-bell it is mounted to. This directly feeds the 4-brush commutated DC motor driving the machine. brushes and fields are series.
    I'll update this, 'cuz I need to observe [ and remind myself ]where the rectifier negative is connected, whether mains return, or chassis green wire.
    Standard fault calling for service, is a blown rectifier, likely caused by excessive start / stop operation, or lousy heatsinking.
  11. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    We are aware that rectifying the line is done. We do not support discussions of it as there is such a large readership, with vastly differing abilities and comprehensions of danger. Without some applied and intelligent effort, it is very easy to cause a lethal shock hazard.
  12. edgetrigger
    Dec 19, 2010
    133
    19
    safety apart! will it be a dead short for the negative half cycle of the A/C?
  13. edgetrigger
    Dec 19, 2010
    133
    19
    I bet in your product it will be connected to mains return. There is no point connecting to chassis ground when you have mains return. I wanted to know if it can be connected to ground(earth) after rectifying. I think it may just blow the supply fuse if in neutral path.
  14. #12
    Nov 30, 2010
    16,671
    7,318
    Putting a bridge rectifier across the mains voltage and grounding one output of the bridge rectifier will absolute, positively, be a short circuit.
  15. edgetrigger
    Dec 19, 2010
    133
    19
    Grounding the bridge negative will not be a short for positive half cycle of the input, i suppose
  16. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    This discussion is really going nowhere. Please refer to post #11.
Thread Status:
