Then stop reading.Originally Posted by Brownout
I get the feeling the OP is doing his best, and the grammer police should chill the feak out. There is a discussion in the off topic forum about how we are here to help even those who has trouble with english. If that's the policy, it's good enough for me.
Perhaps you should re-read posts #13 and #14. It is clear that he is not trying to put actual words together. If he would just take the time to write out full, legible sentences, I can deal with any language barrier beyond that. Our point is that the OP wasn't even trying to type full words. That is what is annoying me.
To be perfectly honest, I've never seen "thx" or "plzzzz" come out of translation software....I think some of the chopped text is the result of using translation software.
You see the same thing too many times to be playing games.
Absolutely correct. That last post showed that you (aimaldaudkhan) can at least put full words together and make coherent posts. That is all that I was asking forGround does not always mean "earth". In electrical and electronic circuits, it would be better to call it "COMMON" meaning it is shared with all of the individual elements that need a reference point.
Other than the Txt speak, your English is much better that most of us could even attempt in your native language. Just avoid the Txt speak and we will all be much better off.
Ground is a reference point that is absolutely critical in every circuit. It creates a path for the current to flow, and it ensures that the voltage at different points is correct.ok sir next time i will care about it. my english is weak
can u explain it why we use ground in circuits
and it is nesessry in circuits?
