Ground
Discussion in 'General Electronics Chat' started by Voltboy, Aug 25, 2007.
  1. Voltboy
    Thread Starter Active Member
    Jan 10, 2007
    197
    Hello..
    I'm trying to read a circuit and build it.. There is a +5v,a -5v a +6v and -6v and one ground. The +5v is connected to the cathode of a 5v battery and the -5v is connected to the anode of the battery, right? So the +6v and -6v are connected same but on a 6v battery. But now the ground, where is it connected?
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    It would be helpful if you could post the schematic.
    hgmjr
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    There have to be more batteries. One 6 volt battery has one output voltage. With a pair of them, connected so one's anode is to the other's cathode and measuring from that common point, there is a + 6 volt and a - 6 volts. The cathode is the negative voltage, by the way. One might be able to run a voltage regulator off the +/- 6 volts to produce +/- 5 volts.
  4. Voltboy
    Jan 10, 2007
    197
    The schematic is in a book so i cant post it but well the +/-6v isn't really part of the +/-5v because the 5v circuit is from the digital circuit and then it activates the 6v circuit to power up a motor but the ground (my bad on the first question).
    To activate the circuit there is a IR phototransistor that when there is IR light it let current pass to the pin 4 of an LM339 (the - input) and to the pin 5 is connected a potentiometer that comes from a +5vdc to the ground so in this circuit to the output be the Vcc the voltage from the IR phototransitor must be bigger than the one from the potentiomenter, right?
    Sorry I cant get a schematic.
  5. hgmjr
    Jan 28, 2005
    9,030
    214
    If you have access to a scanner, you could sketch the circuitry that you are trying to figure out and post it here.
    hgmjr
  6. Voltboy
    Jan 10, 2007
    197
    I made it in Eagle and some paint.. the only thing is the that the pins 4 and 5 go
    the other way, the 4 goes on the 5 and the 5 on the 4, i didnt know how to rotate it, srry.
    And R2 is a potentiometer
    Yoda
  7. Distort10n
    Dec 25, 2006
    429
    Are the anodes of the battery the common of the circuit?
  8. Voltboy
    Jan 10, 2007
    197
    I dont know, this is how the circuit is in the book, i just copy it using eagle.
  9. techroomt
    May 19, 2004
    198
    with the four power sources you mention, a battery will be required for each. a 5v battery which has it's cathode (-) conected to the ground will have +5v potential at it's anode (+) with respect to ground. a 5v battery with it's anode (+) connected to ground will have -5v potential at it's cathode (-) with respect to ground, etc..
  10. mOOse
    Member
    Aug 22, 2007
    20
    Couldn't you use a 12V battery and a voltage divider with two
    equal resistors? The point between the resistors is the common.
    From the anode (+) to common is +6V and
    from the cathode (-) to common is -6V.
    I suppose exactly how the divider resistors are loaded would be
    rather important here, or you won't get the voltage you expect.
    But if the loads were constant it might work.
  11. RiJoRI
    Aug 15, 2007
    536
    26
    The schematic is that of a comparator.
    So the pot will set the sensitivity of the circuit, and when it is exceeded, the OpAmp will change state. Note that in the circuit you show there is only +5V and ground, no -5V (in reference to ground).
    --Rich
