Ground?
Discussion in 'The Projects Forum' started by Lightfire, Mar 29, 2011.
  1. Lightfire
    Oct 5, 2010
    690
    21
    Originally posted by SgtWookie at my earlier post.
    So, I really don't know what is ground or whatever. I got the feeling that the ground that most people are saying is the third wire. What is that? How to install that wire? It can be installed in battery? How?
    Thanks...
    SgtWookie likes this.
  2. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    http://www.hark.com/clips/txctrbvdjh-thats-hilarious
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  4. studiot
    Nov 9, 2007
    5,005
    515
    What is all this about?
  5. Lightfire
    Oct 5, 2010
    690
    21
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Our OP doesn't understand what "ground" is. Hopefully, the Wikipedia link that I posted will help to clear up their confusion.
  7. Lightfire
    Oct 5, 2010
    690
    21
    but it can connect in simple dc circuit??? just project????
  8. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    It could. Battery powered projects are usually "floating" - they have no electrical connection to earth ground. However, it is still common to declare one point of the circuit to be the 0v reference. In the case of a single-supply system, it is most frequently the negative side that is declared to be 0v, or the ground reference point.
  9. CDRIVE
    Jul 1, 2008
    2,223
    99
    After the OP reads those articles be prepared to answer the inevitable question regarding long running discrepancy of the Earth GND vs. Chassis GND symbol. I was taught using the convention that we use here on AAC and in all the Spice programs I've used. Over the years, most schematics have also followed this convention but there's always been the occasional exception. If I were to guess, I'd think that the most probable cause for the discrepancy was born between the electronics industry and the electrical (Electricians Union) industry but not sure. To further muddy the water, most circuits today don't employ a metal chassis. Here at AAC we're dealing with mostly with PCB design which (technically) should be drawn as an inverted triangle to indicate a Common Gnd, Board Gnd, System Gnd, Circuit Gnd, Floating Gnd and any other above ground terms I've missed. From an aesthetics point of view I've never liked it.
    There's yet another ground symbol that I use. See attachment.
    This is a classic "Bar Napkin Ground Symbol" that I like to call the "Lazy Z". :D
  10. Wendy
    Mar 24, 2008
    20,772
    2,540
    I'd never seen the Lazy Z, I'll have to remember.
    Ground, as referenced to electronics only, is the common point. It is where you put the negative lead from your meter, and the other voltages are measure with the positive meter lead.
    Some circuits use more than one power supply. Op amps are the usual example, they use two voltages, a plus and a minus, and ground is where they connect. This is a bit advanced for you, but not too much so.
    My personal convention, where there is only one power supply (or battery), is that negative is always ground. This is pretty common, but not written in stone.
    There was a time with cars, many decades of years ago, that ground was the positive lead from the battery. This has pretty much gone away.
  11. studiot
    Nov 9, 2007
    5,005
    515
    The difficulty with calling the chassis 'ground' is that it may not be.
    At one time many televisions and mains radio sets were build on metal chassis. Many parts of the circuit were connected to chassis, but the chassis was not earthed ( connected to the incoming mains earth ). Indeed in some models the chassis was live.
    Although this is no longer practiced, the symbol for connection still remains and some assemblies of industrial apparatus is built into a metal frame. Connections to such a frame is still correctly represented by this symbol.
    CDrive's lazy z usually represents mains ground.
  12. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
  13. CDRIVE
    Jul 1, 2008
    2,223
    99
