Ground triggered Latching Circuit using transistors
hp1729
Joined Nov 23, 2015
2,304
I have combined your diagram with the Flip Flop I posted earlier and attached it to this post. Is this what you had in mind?
So increase the resistor value to the LED from 330 to 1K. Correct? If so, I didn't show that on the drawing. :(
Are you thinking I need resistor to 12v after the N.O. push button in my drawing?
Thank you for all the input here guys.
TONY
Are those capacitors 100 picofarad or 100 microfarad?
cmartinez
Joined Jan 17, 2007
8,257
TONY
My only observation would be that R9's value seems too high to drive the base of Q1. Probably a 1K to 2K resistor would be better for that purpose.
dl324
Joined Mar 30, 2015
16,943
You're right. I used 200 in my example to give 2X the base current required to insure the transistor saturated. The current in Q1 will be around 300mA, so the base current should be at least 30mA; 200 ohms will give around twice that.
stillgrowingup
Joined Jul 15, 2015
210
So R9 should be 200 ohms, NOT 220k?
TONY
cmartinez
Joined Jan 17, 2007
8,257
Yes. You could try 220K to convince yourself that it won't provide enough base current to saturate the transistor...
And that's the beauty of breadboarding a circuit before making a pcb... it not only allows you to more easily correct mistakes, but also to experiment with endless "what if" scenarios as well. And have a far fuller learning experience in the process.
stillgrowingup
Joined Jul 15, 2015
210
Thank you guys. I have came up with a different drawing, hoping for the same result. The second drawing has less components. Please look them over and offer feedback. Ultimate goal is to have a working circuit that is durable. This circuit will be active for 6 hours per day. Not to mention the heat of sitting car in sunlight during the summer months.
TONY
Alec_t
Joined Sep 17, 2013
14,330
The first circuit won't toggle reliably if there is no pull-up resistor from C1/C2 to the 12V rail.
The second circuit should latch, but I don't see how it will toggle?
stillgrowingup
Joined Jul 15, 2015
210
I added a 10k resistor for a Pull-up. Hopefully in the right spot. :) ... Not sure if 10k will be the right value, but it's a start. I added the updated drawing to this post.
Agree; don't see how the second circuit can toggle.
And I was hoping I understood this when I drew it up. :( .. is the 2nd drawing hopeless?
TONY
cmartinez
Joined Jan 17, 2007
8,257
TONY
Yup, you placed the resistor in the right place. And 10k should be more than enough to bias the node.
stillgrowingup
Joined Jul 15, 2015
210
@stillgrowingup, I suggest you take a look at Mr Chip's blog regarding flip-flop fundamentals. It's quite illustrative.
Thank you. I did find it helpful.
Hello guys,
I have downloaded MulitSim 13 and found it easy to use for a beginner like me. :)
Trying everything I can think of, incorporating some recommendations I you all have given. Thank you. :) I think I have the solution. Using a 4013 IC. Output to handle External Lamp, Relay and LED. Being triggered from a Ground source N.O. push button.
I do have some questions. From what I can tell, this chip can do this same circuit twice, but independently? Is this Correct? I hope so, I need 2 toggle latching circuits.
Can I use a 1N4004 diode across the relay coil instead of a 1N4148? Not sure what the difference is.
C3 is for filtering Automotive noise, figured I needed it.
How do my Cap values look? It does work well in the simulator. But funny thing ... When I try to put the voltmeter on the output of the BD139. It latches on, without releasing. ... Also when I place the Voltmeter across the C1 to measure the cap voltage. It latches on, without releasing. Not sure why.
TONY
dl324
Joined Mar 30, 2015
16,943
Yes. If you had decided to go with the IC sooner, you could have saved everyone some effort...
Yes. The important thing is that the diode be able to handle the relay coil current.
Make sure you put it across the power pins of the flip flop. You may need more (i.e. an electrolytic) because auto electrical can be very noisy.
What is C1 for and why is it so large? If it's for switch debouncing, I'd put it across the switch. I'd also change R1+R2 to be something like 10K.
What is the function of C2 and R4? They seem unnecessary to me.
cmartinez
Joined Jan 17, 2007
8,257
Yes you can, their main difference is their current carrying capability, in which the 1N4004 may be a better choice.
Make sure you place is as close to yout 4013 chip as possible
C1 is HUGE! you could probably use a much smaller value, if you increase R1 a bit more. Try to bring it down to 100uF or less, if you can. Use the simulator to find out the best value for R1
stillgrowingup
Joined Jul 15, 2015
210
Thank you guys.
I have plenty of 1N4004. I'll use those.
Do you mean put C3 right at the pin 14 (Vdd)? Or put the C3 to Pin 7 (Gnd) and pin 14 (Vdd)? .. I also put electrolytic caps in.
Yes it was. It wasn't til I increased the C1 that the switch was steadily toggling. I decreased C1 and changed R1 and R2 values, per your recommendations. Things seem to toggle nicely in the SIM now. :)
I saw this in someone else's circuit. I tried putting them to ground in this SIM. It still worked. I'll see what happens on a breadboard.
In the SIM, circuit becomes active at start up. I do NOT want that. So I first swapped Pin 1 and 2. Then the circuit won't toggle in the SIM. So I next removed the ground from pin 4 (RESET input). Added a the cap to go from pin 4 to +12v. Then 10k resistor needs to go from pin 4 to ground. Hoping the cap will pull the RESET input high by following the 12v supply when first powered on, and then the resistor will charge the capacitor, pulling the RESET input back to ground.
Still the circuit became active on SIM power up. I then increase the resistor to 47k or 100k. Still became active on SIM startup. I next added the other half of the chip to the SIM and grounded pins 10, 9 and 8 I think I need to do breadboard SIM and see what happens.
TONY
dl324
Joined Mar 30, 2015
16,943
I don't think they serve any useful purpose and should be removed; lest more people ask you why they're there and you not having a good reason.
R6 and C4 should reset at power on.
You should put C1 across the switch and remove the parallel resistor.
eetech00
Joined Jun 8, 2013
3,958
What's the total current draw for that incandescent bulb plus the relay and LED?
You'll need to make sure Q1 has enough base current to drive all of them.
dl324
Joined Mar 30, 2015
16,943
Good catch. In the discrete design there was a small signal transistor to boost base drive for the power transistor. OP removed it and it's still needed. Power transistor load is about 300mA and the flip flop will only be able to provide a fraction of the required 30mA.
