2N3906 is a PNP.Thank you for the drawing. How would you trigger the circuit?
Are you saying my least Drawing in post #51 doesn't work? But swapping the 2n3904 to 2N3906 will make it work?
TONY
Will a 1N4148 across the coil's terminals be fast enough to protect the fet?The output of the flip-flop is too heavily loaded in your latest circuit. Simulation shows this prevents toggling.
Here's a variant, which uses a NMOS FET to do most of the donkey-work.
With the flip flop in your most recent schematic.Thank you for the drawing. How would you trigger the circuit?
No problem. If the OP had wanted to make the LED indicator part of the flip flop, I would have suggested N channel MOSFETs instead of BJTs.Right... I was confusing mosfet's behavior with that of bjt's.... thanks for clarifying
Reverse recovery speed is only important when a diode is switching from conducting to nonconducting.Will a 1N4148 across the coil's terminals be fast enough
I understand now ... Where you indicate 'FF OUT' on your drawing. I thought that was YOUR output, not mine. So I was wondering where YOUR input was. Dummy me. Sorry.With the flip flop in your most recent schematic.
Hi. Just use the existing latching circuit and precede it by a simple transistor voltage amplifier, which will invert the signal. Use a pull up resistor on the base. When you ground the base, voila!Hi guys,
I am at a complete loss. I have googled Latching transistor circuits and have only found diagrams using 12v Positive triggers, not a ground trigger. I am looking to build a latching circuit using NPN PNP transistors when pulsed by a N.O. switch to Ground.
Requirements:
Has to work with 12v DC to be used in my car.
Circuit Latches when pulse to ground by N.O. switch. Unlatched when SAME N.O. switch is pressed to ground.
Output from transistors need to offer Full Ground when active. Output will activate an 'On Board' 12v SPST Relay And send a Ground signal to illuminate a 12v Lamp 'OFF board'.
No reset switch needed or will be used.
Would like to have LED on board to light when circuit when circuit is active/Latched.
I'm not looking for someone to the work for me. Hoping Someone here can point me in the right direction for answers or send a link that have answers. Doesn't even have use NPN PNP transistors. That just what I am thinking need to be used.
Any feedback will be great and appreciated.
TONY
That, I didn't know... I've learned something new today. Thanks!Reverse recovery speed is only important when a diode is switching from conducting to nonconducting.
The resistor values aren't that critical. If you're going to keep R10, you should put a matching resistor on the other transistor.So by combining your drawing with mine. That should just about to do it? ... I'm not even sure if the values I put in my drawing are right.
Better. It toggles but it doesn't latch. Did I wire something wrong?The output of the flip-flop is too heavily loaded in your latest circuit. Simulation shows this prevents toggling.
And now for the most complicated solution I could come up with. I left the LEDs in so if you do decide to build it you could see it work. The LEDs can be removed and the relay and all added later.Hi guys,
Requirements:
TONY
Hi,I modified it for my application. See attached.
I've used a 1k resistor in another circuit. LED did not illuminate. I kept change resistor out til LED came on with 330.
What MrAI stated, definitely seems to be "lot more circuitry".
That is VERY detailed. But, I do not even know where to begin on that drawing. Is there an "Over my Head" emoji for your response.
I didn't included those resistors in my newer drawing.
Thank you for all your responses. You guys are great help. I did create a newer drawing based in the TIM17 drawing from post #22.
I need it to be GND trigger pulse Push ON/Push OFF. Have GND Out to illuminate 12v Bulb. Drive a LED when circuit is Active. Latch a 12v relay.
TONY
In the sim it latches ok. But then, sims and reality don't always tally . It may be a timing issue, a transistor gain issue, or dependent on whatever you're using as a trigger. Try tweaking a few of the component values.It toggles but it doesn't latch. Did I wire something wrong?
There is a resistor in parallel with the N.O trigger. I think it could be considered a pull up resistor.Btw, I've just noted you were using a N.O. switch as the trigger. Did you have a pull-up resistor to a positive voltage?
I have combined your diagram with the Flip Flop I posted earlier and attached it to this post. Is this what you had in mind?Total current in the power transistor is about 300mA so loading on the flip flop is too high.
I suggest you add a PNP transistor to drive the BD139 and use a LOW output from the flip flop to turn everything on.
So increase the resistor value to the LED from 330 to 1K. Correct? If so, I didn't show that on the drawing.I'd also reduce the current in the LED. It's just an indicator, so 5-10mA is probably sufficient.
Are you thinking I need resistor to 12v after the N.O. push button in my drawing?But since your switch goes to ground, isn't that a pull-down resistor?
by Duane Benson
by Jake Hertz
by Duane Benson
by Robert Keim
