Ground issues
Discussion in 'General Electronics Chat' started by nathomas, Nov 23, 2011.
  1. nathomas
    Mar 3, 2011
    82
    I have a fan circuit TC642 connected to a microcontroller circuit 16f1519 which is in turn connected to an rtd sensor circuit. the same microcontroller circuit drives an led output. the problem is that when i connect all of them together, something interferes with the fan circuit. is it the common ground that is affecting the circuit? what else can cause the problem...the fan circuit works fine individually but with the led circuit connected it goes haywire..
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    OK, where is your schematic? We really need that.
    Make sure the schematic includes part numbers and/or values for everything.
