I am using a ground fault sensor in conjunction with a controller to protect from stator ground fault on a generator. I have come across several that say they are rated at 10, 20 and so on amps. (the system shuts down only when stator ground fault occurs.)
What I am wondering is what would happen when the current is overloaded beyond what the CT switch is rated at. If you look at the diagram it will show that very high currents can flow while in many other ground fault applications, it is only small fault currents that will flow. Will the saturation cause a regular ground fault CT to be damaged?
Do I need to consider something else for what I am doing?
I have attached a diagram.
