ground clip on oscilloscope
Discussion in 'General Electronics Chat' started by gjo, Oct 28, 2013.
  1. gjo
    May 22, 2013
    28
    What purpose does ground clip serve on oscilloscope connected to isolation transformer
  2. crutschow
    Mar 14, 2008
    13,515
    3,386
    It provides a return path for the signal being measured by the oscilloscope.
  3. WBahn
    Mar 31, 2012
    18,093
    4,918
    Do you mean that you are powering the scope through an isolation transformer, or what you are measuring with the scope is being powered through an isolation transformer, or that there is an isolation transformer between the scope and what you are measuring?
  4. ErnieM
    Apr 24, 2011
    7,443
    1,628
    As far as the ground clip is concerned it doesn't matter. Since a voltage can only exist between two points you need the ground clip for the 2nd point irrespective of it being connected to Earth ground or Pluto.
  5. WBahn
    Mar 31, 2012
    18,093
    4,918
    I agree. I should have stated that this question wasn't directly related to the OP's specific query, but rather just to trying to visualize the setup they are talking about.
  6. GopherT
    Nov 23, 2012
    6,330
    4,072
    Without a ground clip, you will be fine if your circuit under test is connected to the same ground reference as your scope. If your scope is isolated and/or if you are testing a circuit that is isolated (battery or isolation transformer powered), then you will get a lot of noise because the ground clip will be an antenna to all emf. Your probe will also be more of an antenna than a probe because it has only one connection to the circuit.
  7. crutschow
    Mar 14, 2008
    13,515
    3,386
    Not if the signal is high frequency (above about a MHz). Then you need the ground clip connected to the circuit ground close to where the probe is connected. to minimize ringing and distortion of the signal.
  8. GopherT
    Nov 23, 2012
    6,330
    4,072
    True, true, true. I just keep thinking about hobbyists and 555 timer frequencies on this site.
