Hi, I am so confused.. I posted this in "conversations" it felt wrong. Finally I found how to post a new thread, and can only hope I am in the correct sub-topic.
Here it is:
I am adding a Belkin power strip to a single 120v receptacle box. I already have a 6 plug adapter at the box. There are 4 more power strips, 2 have basic surge suppression. Each power strip is running from the 6 plug adapter. I am not over loading. The many power strips are for easy access to an outlet no matter what other consumer electronics units are sitting on the bench, The Belkin is both a surge suppressor and an AC filter, to provide filtering and protection to an oscilloscope and a function generator.
The Belkin strip has an LED indicator that is lighted, telling me it is not grounded. I checked the receptacle box with the 6 plug adapter with nothing else connected. The DMM says the wiring is correct. I then begin adding each power strip one-by-one, the Belkin LED begins to light up and get brighter as more are connected.
SO to Summarize, a 6 plug add-on box at the receptacle. 4 power strips running from the 6 plug add-on. 2 of the power strips are basic surge suppression. Finally, the 5th power strip is the Belkin with both surge suppression and line filtering.
My questions are: Could the other 2 surge suppressor strips affect the proper grounding of the Belkin? Am I missing one of the 4 power strips being miswired? I tested with a DMM,h the 4 power strips all read as correctly wired. Could it be that some other appliance is miswired? If so, why would that affect the rest of the plugs and power strip?
This is about safely wiring up an oscilloscope and a function generator, so it does qualify as ok in this forum, correct?
Here it is:
