Greatest common factor, least common multiple.
Discussion in 'Math' started by strantor, Sep 20, 2011.
  1. strantor
    Thread Starter AAC Fanatic!
    Oct 3, 2010
    4,302
    1,989
    I'm trying to help my neice with her homework over the internet, via her mom who's also trying to help her. I feel like I'm one of those idiots on "are you smarter than a 5th grader" So, here's what I got (this is the email I am sending her mom, with the homework questions in BOLD, and my answer in italics:
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Brian has 45 tanzas because:
    Code ( (Unknown Language)):
    1.
    2. (4 * 11) +1 = 45 = (9*5)
    strantor likes this.
  3. djsfantasi
    Apr 11, 2010
    2,900
    876
    Start with: A*B=2,700
    Factor 2,700 into it's prime components:
    A*B=3*3*3*2*2*5*5
    Shuffling terms around using the knowledge we have that 3*5=15 is the greatest common multiple:
    A*B=(3*5)*(3*5)*2*2*3
    ..and introducing our friends x and y from algebra:
    A=15*x
    B=15*y
    ...and using the leftover terms,
    x*y=2*2*3
    This means there are multiple possibilities for the x and y values.
    x= 1, 2, 4
    y=12, 6, 3
    This results in:
    A= 15, 30, 60
    B=180, 90, 45
    Now using the three possible sets for x and y, I come up with three different answers, depending on which of the three perfectly valid choices we make for the 2 numbers whcih multiply together to get 2,700:
    A= 3*5 =15
    B= 2*2*3*3*5 =180
    Least common multiple =2*2*3*3*5 =180
    A= 2*3*5 =30
    B= 2*2*3*5*5 =90
    Least common multiple =2*2*3*5*5 =90
    A= 2*2*3*5 =60
    B= 3*3*5 =45
    Your neice probably needs one correct answer. I like A=30 and B=90 because it stared me right in the face. In fact, I almost convinced myself it was the only answer.
  4. strantor
    Oct 3, 2010
    4,302
    1,989
    @djsfantasi
    I thought it was going to be a lot simpler than that. I think this stuff is supposed to be pre-algebra. Thanks for the answer, I will let her know.
  5. Zazoo
    Member
    Jul 27, 2011
    114
    43
    One correction, of the remaining factors of 2*2*3 the pair of twos must remain in A or B, if you put a single two in both A and B then the GCF becomes 30 not 15. So the second one won't satisfy the required GCF
    djsfantasi likes this.
  6. Georacer
    Nov 25, 2009
    5,151
    1,266
    What's a tanza anyway?
    I 'd like to justify Papabravo's answer:
    We know that:
    11 \cdot N +1 =9 \cdot K \text{, where }N,K \in \mathbb{N} \Leftrightarrow<br />
K=\frac{11 \cdot N +1}{9}
    The first N that makes K an integer is N=4 and K=5
  7. strantor
    Oct 3, 2010
    4,302
    1,989
    No idea. it's something they have in the philippines I guess (that's where my neice is)
