Great orice on HP Laser Printers
Discussion in 'General Electronics Chat' started by spinnaker, Dec 23, 2011.
  1. spinnaker
    Thread Starter AAC Fanatic!
    Oct 29, 2009
    5,065
    1,170
    If you were looking great price on LJ printer for toner transfer PCBs, look no further if you are from the U.S.
    Tiger Direct has a great price.
    http://www.tigerdirect.com/applicat...mmc=email-_-Main-_-WEBBP1584-_-tigeremail1584
    I wish I would have waited. I paid $90 shipped for a HP P2110W which gives 600 DPI through software but can also go to 1200 DPI.
    Looks like this one does true 600 DPI. I am guessing it also has a rear page exit which the P2110W lacks.
    Downside is that this printer does not appear to be wireless a nice feature of the P2110W.
  2. tom66
    May 9, 2009
    2,613
    214
    But you could buy good quality 2 layer silkscreened PCBs from China, 100qty, for that price...
  3. spinnaker
    Oct 29, 2009
    5,065
    1,170
    Show me where you can buy 100 unique boards and you will have something.
  4. thatoneguy
    Feb 19, 2009
    6,357
    718
    But they'd all have to be the same.
    With this, you can make 100 DIFFERENT boards!
    Plus, PCB in a box sells White RTF to make silkscreened top sides!
  5. spinnaker
    Oct 29, 2009
    5,065
    1,170
    I just toner transfer the silkscreen. It is black but it works. It would be nice to be able to get white toner.
    Can you buy just the silk screen stuff from PCB in a box?
  6. thatoneguy
    Feb 19, 2009
    6,357
    718
    Yes, Just order White RTF Digikey carries it as well.
    Works just like toner transfer, but leaves white printing.
  7. tom66
    May 9, 2009
    2,613
    214
    Not 100, I suppose. Would you settle for 10 each of 10 different designs? That would cost $99 for 5cmx5cm layout. 10 each of 5 different designs at 10cmx10cm would be about $125...
    This does have an application for fast prototyping. But can you do two layer boards? Many designs nowadays are becoming more and more difficult to do on a single layer. Wire jumpers aren't acceptable for high speed or mass production...
  8. spinnaker
    Oct 29, 2009
    5,065
    1,170
    I don't even need 10. I need one. I'm not doing high speed mass production. Just for my own use.
  9. spinnaker
    Oct 29, 2009
    5,065
    1,170
    Do you mean TRF?
    http://www.circuitspecialists.com/pcb-trf-white.html
    digikey seems kind of expensive. Circuit Specialists sells 15ft of it for $7.00
    How does this stuff work? Do you print right on it with the LJ? If so a mirror of regular image of the silkscreen layer?
    And what was that testors green paint you use? Where do you get it?
    How do you paint the board if doing SMD? Through hole?
  10. thatoneguy
    Feb 19, 2009
    6,357
    718
    I actually prefer placed boards, especially when I'm not the one paying for them.
    For home hobby stuff, I've made 2 sided boards, vias were a bit of a pain, but alignment wasn't so bad, as long as you put the board outline on both transfers, outside the edge of the board, so the toner just touches the board all the way around.
    Then spray with Testors transparent candy green, let dry a day, add white RTF one side, place and solder, the green looks like solder mask, but isn't.
  11. spinnaker
    Oct 29, 2009
    5,065
    1,170
    If you spray before you place components then do you need to scrap the paint on the pads?
  12. thatoneguy
    Feb 19, 2009
    6,357
    718
    It burns away with the soldering iron, a bit of a pain, but if you want it to look neat, there ya go.
    I've tinned pads before spraying lately so it goes easier, but then it looks "pro" for a cheezy gift or for kids at show and tell.
