gray to (7 2 -1 -3) only with 4to1 MUX
Bogdann
Joined Jul 31, 2012
5
Hello
I need to implement this conversion of gray code to (7 2 -1-3)code using only 4to1 Multiplexers.
here are the codes codes:
EDIT: seams like copu-paste from excel wont work :D i ll update this when i come back at home ...
just ignore this thing that should have been nice table :)
gray 7 2 -1 -3 w x y z f1 f2 f3 f4 0 0 0 0 0 0 0 0 0 1 0 0 0 1 0 1 1 0 2 0 0 1 1 0 1 0 0 3 0 0 1 0 1 0 1 1 4 0 1 1 0 1 0 0 1 5 0 1 1 1 1 1 1 1 6 0 1 0 1 1 0 1 0 7 0 1 0 0 1 0 0 0 8 1 1 0 0 1 1 1 0 9 1 1 0 1 1 1 0 0 10 1 1 1 1 x x x x 11 1 1 1 0 x x x x 12 1 0 1 0 x x x x 13 1 0 1 1 x x x x 14 1 0 0 1 x x x x 15 1 0 0 0 x x x x
k-maps:
f1=yzx'+x+w
Wx\yz
00
01
11
10
00
01
11
x
x
x
X
10
x
f2=yz'x'+y'z+w
Wx\yz
00
01
11
10
00
01
11
x
x
x
X
10
x
x
etc...
Now i am not sure if this k-maps are ok, but if we assume they are ok :)
what is the next step? I tried with shannons theorem but i cant get this right.
It ll be really nice if someone can help me with implementing at least one function.
WBahn
Joined Mar 31, 2012
30,076
Yeah, you're gong to have to format it better. But, also, you need to explain what a 7 2 -1 -3 code is. Are these the weightings on the bits in a four bit integer? If so, then your values run from -4 to +9. You need to define how the gray code vectors (which don't have any intrinsic value) are mapped to values in this range.
