Graphing the Trigonometric Fourier spectra
Discussion in 'Homework Help' started by nyasha, Oct 27, 2011.
  1. nyasha
    Thread Starter Active Member
    Mar 23, 2009
    90
    So l just need to be pointed in the right direction and the rest l will do myself. How do l get the amplitude and phase for ω=2t. There is a sine and cosine with ω=2t. How do l deal with them.
  2. chrisw1990
    Oct 22, 2011
    543
    41
  3. nyasha
    Mar 23, 2009
    90
    I do understand how to get the Fourier series. The given signal is a already a calculated fourier series they just want it to sketch its Fourier spectra. I am confused on what to do at ω=2t
  4. MrChips
    Oct 2, 2009
    12,652
    3,461
    You probably meant to say at ω=2.
    The amplitude would be the square-root of the sum of squares:
    <br />
\sqrt{(\sqrt{3})^2 + 1^2} = \sqrt{4} = 2<br />
    See if you can figure out the phase on your own.
  5. nyasha
    Mar 23, 2009
    90
    And the phase is 30 degrees. I now get it. Thanks man.
  6. MrChips
    Oct 2, 2009
    12,652
    3,461
    Well the phase angle is either 30 or 60 degrees. Try to figure out which is the correct answer.
