Graphing decaying sinusoids by hand?
Discussion in 'Math' started by dewasiuk, Feb 26, 2011.
  1. dewasiuk
    Feb 14, 2011
    24
    How could this be roughly accomplished without making an extensive table of values?
    For example if I use the laplace method of analyzing an RLC circuit with a pulse excitation, I know that I will arrive at a decaying sinusoidal current represented by the following equation: [​IMG]
    I would like to be able to quickly graph the equation incase I didn't have access to software tools at that moment.
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    For your given example
    1. Draw the exponential envelope bounded by the curves
    f1(t)=e^{-\alpha t}
    and
    f2(t)=-e^{-\alpha t}
    2. Draw a sinusoid constrained in amplitude by the bounded region with damped period
    T=\frac{2\pi}{\omega}
    Since it is a sine function in this particular case the value at t=0 will be zero. If it were a simple cosine function the initial value would be 1. A phase displaced sine or cosine function would have an initial value determined by the value of the sine or cosine term at t=0 sec.
  3. t_n_k
    Mar 6, 2009
    5,448
    783
    Here's an example sketch of a phase shifted exponentially decaying cosine function.
  4. dewasiuk
    Feb 14, 2011
    24
    Oh I already know how to roughly sketch the actual shapes, but it's mostly about determining the amplitude of the first peak(for a sine wave) so I can draw it more accurately. I should have included that in my first post sorry.
  5. Georacer
    Nov 25, 2009
    5,151
    1,266
    Peaks and zero-crossings still occur in the multiples of pi/2, so these are points in time you look for.
    For example, your first peak will be at the intersection of the envelope with the line x=pi/2 for a sinusoidal curve.
    That is, of course, for zero time-shift. Shift your times accordingly for θ<>0.
  6. dewasiuk
    Feb 14, 2011
    24
    Damn I feel silly for not thinking about this first haha. Thanks :)
