Graphic Equalizer-Baxandall
Discussion in 'Wireless & RF Design' started by tam72f1, Oct 6, 2014.
  1. tam72f1
    Aug 19, 2014
    15
    I found a design on the internet and i want to make a circuit from this design but i don't understand about it, such as how to calculate some values: center frequencys, resistor.... I want to understand about because if have some problem i can repair and calculate again some value!
    Does anyone help me calculate this circuit!! Thank you very much
  2. Alec_t
    Sep 17, 2013
    5,973
    1,135
    Welcome to the forum.
    The calculations would be quite extensive. I suggest you download (free) the LTspice simulator from Linear Technology and run a simulation of the circuit. That will enable you to try different component values and study their effect. Let LTspice do the calculations for you! ;)
  3. tam72f1
    Aug 19, 2014
    15
    I have a next question. What is misson of capacitor C2????
  4. Alec_t
    Sep 17, 2013
    5,973
    1,135
    It couples AC signals from IC1 output to the filter network.
  5. Jony130
    Feb 17, 2009
    3,991
    1,116
