graphic displays
Discussion in 'Embedded Systems and Microcontrollers' started by reema paul, Aug 12, 2010.
  1. reema paul
    Jun 28, 2010
    12
    hello all,
    can someone please help me find an IC which has 5 fast ADCs and which has built in graphic functionals like graphic drivers.
    i am basically searching an IC which is basically built for displays but should also have fast ADCs in it.
    thank you all
  2. DumboFixer
    Feb 10, 2009
    219
    34
    Can't you use a micro controller ? This will give you the ADC's and one of the many C/Basic compilers will give you the graphics routines and any that are missing could be written.
  3. retched
    Dec 5, 2009
    5,201
    313
    I second that. You would gain much more functionality with a uC. And depending on what type of graphic functions and resolutions, you may want to look into DSP micro controllers.
    The DSPic is a good place to start.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The definition of "fast" and the necessary number of bits per ADC is very significant. How often do you need to sample each input?
