Grammar rule or way of saying
Discussion in 'Off-Topic' started by Alberto, Sep 15, 2009.
  1. Alberto
    Thread Starter Active Member
    Nov 7, 2008
    169
    36
    DELETED! End of my partecipation to AAC forum.
  2. jpanhalt
    Jan 18, 2008
    5,699
    909
    The general rule is that use of "a" or "an" is driven by the way the following word is pronounced. Thus, "an L" is correct, because "L" is pronounced as if it were spelled "el."
    Thus, if you read LED as L.E.D. (i.e., you say the separate letters), the the correct article is "an." If for some reason you pronounce it as a single word (such as the verb, led), then the article would be "a."
    John
    Edit: How to handle the plurals of acronyms, trademarks (usually none), and units is outside the scope of your question, I believe.
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The article goes with the way one pronounces LED. If it is with the letters individually pronounced - L * E * D - then "an" is acceptable. Otherwise, it's a LED (pronounced as "lead").
    The fun part is that the pronunciation of "LED" is not set - it's up to the speaker. You can only tell how he does it by the article preceding the acronym.
  4. Ratch
    Mar 20, 2007
    1,068
    Alberto,
    The best rule I can think of is don't let the consonant "n" in "an" flow into another consonant, and don't let the "a" in "a" flow into a another vowel. So "an LED" is a no-no. By the way, speaking of grammar, "english grammar" is "English grammar" because "English" is a nationality, and is always capitalized in the King's English.
    Ratch
  5. jpanhalt
    Jan 18, 2008
    5,699
    909
    Sorry, and with all due respect, it's the pronunciation not the spelling that governs, particularly for acronyms. Follow my example of "an L."
    John
    Edit: Here are two other examples: "an hour" and "a horse."
  6. someonesdad
    Jul 7, 2009
    1,585
    141
    As someone else mentioned, it's how it sounds when speaking that determines whether 'a' or 'an' are used. Ratch's rule is close, but fails with e.g. 'URL', as the 'U' is pronounced more like a hard consonant than a soft vowel. No doubt some linguist or pedantic English teacher could construct an exact rule, but I suppose a practical rule could be made from where your tongue is with respect to your teeth or whether your lips are closed when saying the letter.
    I can see how it can be hard for a non-native speaker to determine the proper usage.
  7. ELECTRONERD
    May 26, 2009
    1,146
    16
    I'm not so sure "an" is correct, but rather "a". You see, if we unravelled the acronym LED and had "Light Emitting Diode," "An Light Emitting Diode" doesn't agree gramatically. However, "A Light Emitting Diode" does make sense. Therefore, I think "A LED" would be correct and also "One LED" would be alright as well.
  8. jpanhalt
    Jan 18, 2008
    5,699
    909
    When unsure, there are lots of resources available.
    http://owl.english.purdue.edu/owl/resource/540/01/
    John
  9. ELECTRONERD
    May 26, 2009
    1,146
    16
    Well then, according to your resource I am correct. ;) "L" is certainly not a vowel and therefore it's a consonant. It sounds correct anyway.
  10. Ratch
    Mar 20, 2007
    1,068
    jpanhalt,
    Agreed. I never said anything about spelling. I said consonant. The dictionary defines consonant as a. (in English articulation) a speech sound produced by occluding with or without releasing (p, b; t, d; k, g), diverting (m, n, ng), or obstructing (f, v; s, z, etc.) the flow of air from the lungs (opposed to vowel).
    The "L" sound you are talking about is pronounced as "EL", so "an L" sounds good because of its vowel sound. "A LED" sounds good because of its consonant sound. So again I say, don't let the consonant "n" in "an" flow into another consonant, and don't let the "a" in "a" flow into another vowel.
    Ratch
  11. jpanhalt
    Jan 18, 2008
    5,699
    909
    So, how do you pronounce "LED?" And, how about "IRED?"
    The vast majority of people pronounce LED (when meaning a light emitting diode) by saying the individual letters. The first letter of which is not a consonant sound.
    Even if you might pronounce LED as the verb "led," you must admit that many people pronounce LED as the individual letters, which is clear in the preceding posts. Therefore, to say, "an LED is a no-no" is simply wrong.
    John
  12. loosewire
    Apr 25, 2008
    1,584
    435
    When You guys get bored,you should go out to your car
    and check your awl and water. Grammar has a south sound,
    Southern Ohio beat the a's. Loosewire's English.
    Where as,where by.
  13. Ratch
    Mar 20, 2007
    1,068
    jpanhalt,
    1A) an el,ee,dee
    1B) a LED as in led (past tense of lead)
    2) always use "an" whether you pronounce IRED as a word or spell it out
    Ratch
  14. loosewire
    Apr 25, 2008
    1,584
    435
    I think different expression's of langage has to do with the
    subject and meaning of words, a book of facts should be clear
    concise to explain a point clearly. A novel or general reading
    can be more relaxing written as spoken by the subject,to get
    more of a feal of that person being written about,the person
    place,subject.Like my writing you have to figure out what I am
    saying.Some times my mind is moving faster than my typing.
  15. ELECTRONERD
    May 26, 2009
    1,146
    16
    Yeah, A Light Emitting Diode is the correct way just by itself, and An Infrared Light Emitting Diode would be correct if you add the infrared to it.
  16. Ratch
    Mar 20, 2007
    1,068
    Alberto,
    As was pointed out before, the rule applies to how it sounds, not how it is spelled. So when you say LED, you are using the "leh" sound, which is a consonant.
    Nope. A word designated to be capitalized does not lose that status if it is used as an adjective. Two examples are "Boolean algebra" and "Boole's inequality", both named after George Boole.
    Ratch
  17. studiot
    Nov 9, 2007
    5,005
    515
    Since neither the UK, nor any of you guys have a king to have any english the term is moot.
    Alberto et al if you have to have a rule then try this
    a led
    an ell ee dee
    note the spelling if the word following an - it starts with a vowel. This is the spelling of the name of the letter l.
    All totally self consistent.
    However the beaty of the Bard's English is that there are no hard and fast rules, sometimes we make exceptions in the name of expediency as in john'd
    an hour
  18. FastEddie
    Jul 14, 2007
    35
    I'm just curious. If you were talking about a(an) USB cable instead of LEDs which would it be:
    a USB cable
    or
    an USB cable
    I guess if it were plural it would have to be 'the USB cables', so no problem there.
  19. jpanhalt
    Jan 18, 2008
    5,699
    909
    Regarding the indefinite article, you should review the numerous comments regarding pronunciation. How do YOU pronounce "USB?" If you pronounce the individual letters, the correct article is "a." If you try to pronounce it as a single word, as apparently some people do with LED, then the correct article depends on how you make the beginning sound. If that sound is like "ooo", as in boo, then the article is "an." If it is more like "u" as in uniform, then the article is an "a."
    In you example, you made the noun into an adjective, so the singular USB is correct.
    If you want the plural, either USBs or USB's can be used. Neither is absolutely correct or wrong, but your editor may have a different opinion. There is a preference for USBs as the plural and USB's as the possessive (as in USB's output ).
    John
  20. Wendy
    Mar 24, 2008
    20,772
    2,540
    I say the letters, always. Makes it hard to misunderstand, be it LED or USB or PSU (think how that last would sound pronounced).
