Graduation project . need help
Discussion in 'Programmer's Corner' started by Mais, Mar 19, 2009.
  1. Mais
    Mar 19, 2009
    Hi i'm new entry here so Hello all :)
    i have this problem with my project,i need to know how to make acamera on astepper motor tracks amoving object...
    i know it's about image processing and comparing the images bits and then with (-ve) feed back it moves i know that but the thing donno how to write aprograme to do that,any help? :) besides i donno agood resourses for understanding the image processing thing :)
    thanks in advance for any help i may get :D
  2. kokkie_d
    Jan 12, 2009
    Best start of with black and white camera, because it is easy to track a high (white) or low 9black) pulse given out by the camera.
    A bnc connected camera CCTV camera gives out a series of pulse divide by a new screen pulse. Using this you could rebuild the screen in memeory and compare 2 memory scrrens together. this would give you movement of a light source in front of the camera and thus you should be able to track that.
    this is a very simple approach and I recon there are some comparing (with movement) algorithims out in open source).
    good luck
