GPU vs (CPU+GPU) in regard to OpenCV
Discussion in 'Embedded Systems and Microcontrollers' started by Madnness, May 1, 2014.
  1. Madnness
    Apr 16, 2014
    I have two questions.
    First, Is it possible to hardcode an OpenCV algorithm onto a GPU without needing a CPU/OS?
    Secondly, if the answer to the first question was a NO... then what is the lowest CPU processing speed that would be necessary for me to process video (720p) from a GPU(such as a BCM3835) with a simple Blob+Color Detection algorithm with OpenCV and stream it with SSH?
    If either of these sound a little to vague or like there are holes within the questions(i.e. more info needed), I can clarify more.
    Thank you :)
  2. shteii01
    Feb 19, 2010
    3,499
    511
    I don't see how.
  3. kubeek
    Sep 20, 2005
    4,686
    805
    You possibly could interface the standalone GPU over pci-e bus, for example from an fpga. However I don´t see why would you want to go through such trouble when you can use the PC, drivers and OS to ease your work.
