GPS to Radio Controlled Atomic Clock
Discussion in 'The Projects Forum' started by hyiu00, Oct 6, 2013.
  1. hyiu00
    Mar 11, 2013
    The purpose of this simple DIY project is to build an electronic circuit that received the GPS time signal, convert it to the radio-controlled clock format, and transmit that signal to the clock. Once built, there is no need for setup and maintenance, all you need is put this unit close to the window to receive GPS signal, and it will transmit the time signal to your radio-controlled clock.
    http://sourceforge.net/projects/gpstoradiocontrolledclock/
  2. Dodgydave
    Jun 22, 2012
    5,172
    778
    or just buy a ready made atomic clock,,,
  3. KJ6EAD
    Apr 30, 2011
    1,426
    364
    I think you're missing the point. The purpose of the project is to recreate the WWVB time signal for the atomic clock where it could not normally be received, in a deep valley for example.
  4. sirch2
    Jan 21, 2013
    1,008
    351
    Nice idea, thanks for posting
  5. hyiu00
    Mar 11, 2013
    Just updated to version 1.1. Now it supports China BPC code.
