GPS 12v Activated switch at set MPH
Discussion in 'General Electronics Chat' started by scottmoser56, Jul 13, 2016.
  1. scottmoser56
    Jul 13, 2016
    I have a 3 wire 12v actuated electric shut off that I want to use GPS to activate at a set MPH, let's say when you reach 5mph sends a signal that opens the shut off and at 10mph it will close it. This is all new to me, I am using a toggle right now but I want to convert it to GPS so I never have to use the toggle switch. I would need to be able to adjust the MPH both on the open and close, or simply shut it off.
  2. Aleph(0)
    Member
    Mar 14, 2015
    356
    339
    scottmoser56 if that's a question I say you already answered it with use of 5 mph hysteresis so what's the problem:confused:?
  3. KeepItSimpleStupid
    Mar 4, 2014
    1,265
    222
    if this is a car there are ways to do this. One is through OBDII and another, that could be easier is devices that monitor the CAN bus.
