Gould Oscilloscope DataSys, 9500 etc
Discussion in 'Electronics Resources' started by Jester123, Dec 11, 2015.
  1. Jester123
    Aug 23, 2014
    Does anyone out there have a Gould Oscilloscope either a DataSys, 9500 or similar that has the 8 pin circular probe power connector on the back?
    If you do I would really appreciate if you could measure the voltages on the probe power connector. I have a Gould Differential probe that I would like to use with another scope, however I can't use it because I don't know the pin-out of the probe power connector. The connector has 8 pins and the center pin is most likely ground as a black wire is connected to it, and various other colored wires connect to the remainder of the pins. The connector looks like this:
    Much appreciated.
