Got to get me one of these !
Discussion in 'Off-Topic' started by R!f@@, May 13, 2012.
  1. R!f@@
    Thread Starter AAC Fanatic!
    Apr 2, 2009
    8,789
    771
    See this
    Will somebody tell me how I can make on of this. :D
    Puleeeeeeeeeeeeeeeeees!
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Can you cut plastic? All it is is a ceiling fan with specialized blades. I suspect it isn't as efficient as a conventional ceiling fan.
  3. #12
    Nov 30, 2010
    16,685
    7,323
    If you heat the plastic gently you can get a twist so it will move air as well as look nice.
  4. maxpower097
    Feb 20, 2009
    795
    388
    Having a lil experience in this if you do try to make your own. The most important thing is make sure your fan is balanced. If its slightly off, you won't notice it at first but as speed gains or you leave it to wear you'll end up with a fan on your floor. When I was a kid I knocked a blade off a ceiling fan. Took about a month for it to throw itself off the nuts and bolts.
  5. loosewire
    Apr 25, 2008
    1,584
    435
    Do they grow mushrooms on the Island,a half dozen and save $299.00.
    Repeat as needed.
    maxpower097 likes this.
  6. t06afre
    May 11, 2009
    5,939
    1,222
    That fan will match your storage containers just perfect R!f@@. Do you like doing things like decorating and selecting out new curtains for your friends R!f@@ ;)
